Red popup when sending fax
On several 3.1.0 -1 and 3.1.1-1 servers I am seeing a red pop-up with a number (increases by one with each fax). It doesn’t affect the sending of the fax, and I have also updated via yum, and restarted. Is this just a GUI issue?
Do you see anything in the browser console?
@amicusvoice,
It seems to be the log ID returned in the API calls. We will check it.
