I don’t know why SSL Letscrypt did not do fully update some file.
Now we can’t access via domain name or public IP address anymore.
Any solutions
There are two main reasons why Let’s Encrypt might not be working::
1.- Make sure port 80 an 443 is not blocked by the firewall.
2.- If you have installed the GeoFirewall module, do not block the USA, since the let’s Encrypt server needs access to create or renew the certificate and these servers are generally in the USA.
If you cannot enter the interface because the certificate expired and it cannot be renewed, we recommend doing a configuration reset and re-creating the certificate from the interface. For this we use the following command from the console:
vitalpbx --reset-apache-conf
Thanks , is working now
