Hi everybody,
I have an extension with 3 SIP users (Username/password)
I need a to add a 4 sip user, under then extension, but, with IP peering (IP auth) so basically XX@IP:PORT
Can anyone point me in the right direction?
Hi everybody,
No, it is not possible create an extension device that uses IP Auth. Nonetheless, you can use the trunk module to create that type of devices.
