So I installed Vitalpbx via the VPS script on a dedicated server that already had Centos 7 running it. The installation was successful however when I go to the IP address I don’t get the Vitalpbx login screen, I keep getting the Apache Page (see below). Not sure if I did something wrong or not.
Testing 123…
This page is used to test the proper operation of the Apache HTTP server after it has been installed. If you can read this page it means that this site is working properly. This server is powered by CentOS.
