Hi VitalPBX,
I follow instruction on GitHub - VitalPBX/click2call: This is a simple example to demonstrate how to implement click2call feature using VitalPBX API. and use webrtc phone as softphone.
My Question :
How to remove text “VitalPBX : click to call” on call history?
miguel
2
Do you want to see a different value there? or Do you want to fully delete the call history?
Hi Sir,
Remove text “VitalPBX: Click to Call”
Before : VitalPBX : Click TO Call - 77590088
After : 77590088
Or remove “VitalPBX” text
Before : VitalPBX : Click To Call - 77590088
After : Click To Call - 77590088
Hi Sir,
Do you have update? I don’t find word “VitalPBX” on script click to call.
I think this is set by the VitalPBX API.
You can recreate it with your own AMI config.
Hi Team
Can you confirm that whether Click to call feature is available on/or can be integrated with Vitxi Webrtc.
Ashish
miguel
8
You have to use VitalPBX’s API to integrate the Click to Call with any of your applications.
Click to Call API
miguel
9
In the most recent version of VitalPBX, you can define de CallerID name and number to show; this helps to remove or customize the VitalPBX word.
Click to Call API
