Our trunk provider supports G.711u OR G729 CODECs.
I don’t see these listed on the Select Codecs page of the Trunks module.
Is there a way to add these?
When you create the trunk there is a Codecs field, there you select the codecs you want, if you leave it blank it will select the codes that are in Sip Setting or PJSip Settings depending on the technology of the trunk you are using.
The G.711u is ulaw and G729 is g729, see the attach picture.
